Introducción
If you're having trouble with your laptop turning on or holding a charge then you may need to change the battery. This guide will help you to replace the battery.
Qué necesitas
Turn the laptop upside down and locate the ten screws holding in the plate cover.
Remove all ten screws using a small Phillips head screwdriver.
Casi Terminas!
Conclusión
