Saltar al contenido principal
Asus X751L DVD Drive Replacement
Qué necesitas
  1. Asus X751L DVD Drive Replacement, Keyboard: paso 1, imagen 1 de 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L DVD Drive Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L DVD Drive Replacement: paso 3, imagen 1 de 3 Asus X751L DVD Drive Replacement: paso 3, imagen 2 de 3 Asus X751L DVD Drive Replacement: paso 3, imagen 3 de 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L DVD Drive Replacement, DVD Drive: paso 4, imagen 1 de 1
    • With the keyboard panel open, face the laptop with the internal components facing towards you.
    • Remove the single 4.6mm Phillips #00 screw.
  5. Asus X751L DVD Drive Replacement: paso 5, imagen 1 de 1
    • Pull the optical drive out.
Conclusión
2 personas más completaron esta guía.
Carl Ravina
Miembro Desde 02/02/17
125 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 17-2, Blackwell Spring 2017 Miembro de USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Miembros
5 Guías creadas
Un comentario
Spot on, took away any worries…………
paul pepper - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 22
Todo El Tiempo: 2,288
