Saltar al contenido principal
Asus X751L Battery Replacement
Qué necesitas
  1. Asus X751L Battery Replacement, Keyboard: paso 1, imagen 1 de 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: paso 3, imagen 1 de 3 Asus X751L Battery Replacement: paso 3, imagen 2 de 3 Asus X751L Battery Replacement: paso 3, imagen 3 de 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: paso 5, imagen 1 de 2 Asus X751L Battery Replacement: paso 5, imagen 2 de 2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: paso 6, imagen 1 de 3 Asus X751L Battery Replacement: paso 6, imagen 2 de 3 Asus X751L Battery Replacement: paso 6, imagen 3 de 3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
Conclusión
4 personas más completaron esta guía.
John Enderton
Miembro Desde 02/02/17
576 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 17-2, Blackwell Spring 2017 Miembro de USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Miembros
5 Guías creadas
6 comentarios
Very nice, thank you !
anh
barzamjavel - Contestar
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Contestar
Your instructions were easy to follow. Thank you!!!
theresa collet - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 53
Todo El Tiempo: 12,758
