Saltar al contenido principal
Asus X55C HDD (Hard Disk Drive) Replacement
Qué necesitas
Resumen del Video
  1. Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): paso 1, imagen 1 de 3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): paso 1, imagen 2 de 3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): paso 1, imagen 3 de 3
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Asus X55C HDD (Hard Disk Drive) Replacement: paso 2, imagen 1 de 3 Asus X55C HDD (Hard Disk Drive) Replacement: paso 2, imagen 2 de 3 Asus X55C HDD (Hard Disk Drive) Replacement: paso 2, imagen 3 de 3
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  3. Asus X55C HDD (Hard Disk Drive) Replacement: paso 3, imagen 1 de 1
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
Conclusión
4 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,368 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,463 Guías creadas
Un comentario
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
Chris Deiotte - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 39
Todo El Tiempo: 11,422
