Saltar al contenido principal
Asus X55C Cooling / FAN System Replacement
Qué necesitas
Resumen del Video
  1. Asus X55C Cooling / FAN System Replacement, Keyboard: paso 1, imagen 1 de 1
    • Switch off the laptop and remove the battery.
  2. Asus X55C Cooling / FAN System Replacement: paso 2, imagen 1 de 3 Asus X55C Cooling / FAN System Replacement: paso 2, imagen 2 de 3 Asus X55C Cooling / FAN System Replacement: paso 2, imagen 3 de 3
    • The Keyboard is held by 5x locking clips.
    • Pick up a little the one side of the Keyboard and start opening the clips one by one.
    • Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • Please SUBSCRIBE to my channel ツ
  3. Asus X55C Cooling / FAN System Replacement, Motherboard: paso 3, imagen 1 de 2 Asus X55C Cooling / FAN System Replacement, Motherboard: paso 3, imagen 2 de 2
    • Remove 3x Philips screws.
    • Disconnect the two small flex cables:
    • Power On button flex cable
    • Touch pad flex cable
  4. Asus X55C Cooling / FAN System Replacement: paso 4, imagen 1 de 3 Asus X55C Cooling / FAN System Replacement: paso 4, imagen 2 de 3 Asus X55C Cooling / FAN System Replacement: paso 4, imagen 3 de 3
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  5. Asus X55C Cooling / FAN System Replacement: paso 5, imagen 1 de 2 Asus X55C Cooling / FAN System Replacement: paso 5, imagen 2 de 2
    • Disconnect the two coaxial antenna cables from the Wi-Fi card.
    • Remove any Memory or Dummy card.
  6. Asus X55C Cooling / FAN System Replacement: paso 6, imagen 1 de 3 Asus X55C Cooling / FAN System Replacement: paso 6, imagen 2 de 3 Asus X55C Cooling / FAN System Replacement: paso 6, imagen 3 de 3
    • The bottom cover is held by 10x Phillips screws. Remove them.
    • With a plastic tool separate the Upper cover and remove it.
  7. Asus X55C Cooling / FAN System Replacement: paso 7, imagen 1 de 3 Asus X55C Cooling / FAN System Replacement: paso 7, imagen 2 de 3 Asus X55C Cooling / FAN System Replacement: paso 7, imagen 3 de 3
    • Disconnect:
    • The Microphone cable
    • The LCD Display flex cable
    • Remove 3x Pillips screws.
    • Lift the board first from the right edge.
    • There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
  8. Asus X55C Cooling / FAN System Replacement: paso 8, imagen 1 de 2 Asus X55C Cooling / FAN System Replacement: paso 8, imagen 2 de 2
  9. Asus X55C Cooling / FAN System Replacement, Cooling / FAN System: paso 9, imagen 1 de 3 Asus X55C Cooling / FAN System Replacement, Cooling / FAN System: paso 9, imagen 2 de 3 Asus X55C Cooling / FAN System Replacement, Cooling / FAN System: paso 9, imagen 3 de 3
    • Disconnect the Fan cable from the Motherboard.
    • Remove the screws (4x Phillips screws) that hold the cooling system to the Motherboard
    • CPU Cooling System - Cooling Heatsink and Fan.
    • Remove the Cooling System carefully, if you don't want to break the CPU.
    • Before installing the new Cooling System, clean the CPU and put new thermal compound / paste.
Conclusión
Una persona más ha completado esta guía.
ZFix
Miembro Desde 12/09/13
191,308 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,534 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 3,132
