Saltar al contenido principal
Asus X553MA-BPD07051 Battery Replacement
Qué necesitas
Resumen del Video
  1. Asus X553MA-BPD07051 Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus X553MA-BPD07051 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Battery Replacement: paso 2, imagen 1 de 1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Battery Replacement: paso 3, imagen 1 de 2 Asus X553MA-BPD07051 Battery Replacement: paso 3, imagen 2 de 2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 Battery Replacement: paso 5, imagen 1 de 2 Asus X553MA-BPD07051 Battery Replacement: paso 5, imagen 2 de 2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Battery Replacement: paso 6, imagen 1 de 2 Asus X553MA-BPD07051 Battery Replacement: paso 6, imagen 2 de 2
    • Lift the battery up and remove it completely from the laptop.
Conclusión
4 personas más completaron esta guía.
Equipo
2 comentarios
I used your guide when i repaired my mates X553. I found it quite easy. So thanks for the heads up on what to look out for :-)
gazza667 - Contestar
Easy with the use of these clear instructions. Thanks and keep up the good work.
Marc Leclair - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 30
Todo El Tiempo: 2,234
