Introducción
A laptop battery's performance naturally decreases with time, so replacement is necessary to maintain high performance and charge duration.
Herramientas
Partes
No se requieren partes.
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
48 personas más completaron esta guía.
6 Comentarios
Hi there! I have replaced my battery but the new one does not charge. Does anyone have any idea on how to solve it? I have tried several possible solutions found online like removing the battery (completely) turning on the CPU and then off, placed the battery and restarted. Pressing the power button for 15s or 60s and then turn on the CPU.... well.... Loosing hope here.... :( Help!
