Saltar al contenido principal
Asus X550ZA-SA100603E Battery Replacement
Qué necesitas
  1. Asus X550ZA-SA100603E Battery Replacement, Keyboard: paso 1, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Battery Replacement: paso 2, imagen 1 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 2, imagen 2 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 2, imagen 3 de 3
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Battery Replacement: paso 3, imagen 1 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 3, imagen 2 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Battery Replacement: paso 4, imagen 1 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 4, imagen 2 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 4, imagen 3 de 3
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Battery Replacement: paso 5, imagen 1 de 1
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E Battery Replacement, Battery: paso 6, imagen 1 de 2 Asus X550ZA-SA100603E Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Disconnect the multi-wire battery plug from the motherboard.
  7. Asus X550ZA-SA100603E Battery Replacement: paso 7, imagen 1 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 7, imagen 2 de 3 Asus X550ZA-SA100603E Battery Replacement: paso 7, imagen 3 de 3
    • Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
Conclusión
6 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 6,149
