Saltar al contenido principal
Asus X540S notebook PC Hard drive Replacement
Qué necesitas
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S notebook PC Hard drive  Replacement: paso 2, imagen 1 de 1
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S notebook PC Hard drive  Replacement: paso 3, imagen 1 de 3 Asus X540S notebook PC Hard drive  Replacement: paso 3, imagen 2 de 3 Asus X540S notebook PC Hard drive  Replacement: paso 3, imagen 3 de 3
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
  3. Asus X540S notebook PC Hard drive  Replacement, Hard drive: paso 4, imagen 1 de 2 Asus X540S notebook PC Hard drive  Replacement, Hard drive: paso 4, imagen 2 de 2
    • Remove the one Philips #1 screw.
    • Slide the hard drive out.
  4. Asus X540S notebook PC Hard drive  Replacement: paso 5, imagen 1 de 2 Asus X540S notebook PC Hard drive  Replacement: paso 5, imagen 2 de 2
    • Remove the four Philips #1 screws.
Conclusión
18 personas más completaron esta guía.
Padraic Hoselton
Miembro Desde 08/22/17
4,180 Reputación
12 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,528 Guías creadas
7 comentarios
Looks simple enough Padraic. Thanks. Does a new install of win10 come already copied in a new HDD? Would this replacement be and different if I used a digital drive? (My old hd failed and I have no system).
sludge - Contestar
After installing an OEM replacement HDD in my x540, I bought a flash drive on Amazon for$10 that rebooted my Windows 10 and it's working like a brand new machine.
I believe the product key for windows 10 is embedded in motherboard.
F S -
F S - Contestar
Hi … How can a flashdrive reboot a Win10 on a new SDD /HDD ? A Windows flash drive contains a Win10 bootable ISO ?
On Amazon, I found flash drives with a product key but I don’t know where the new installation can be done from if there is no ISO on it …
(I have a x540 with a dead HDD …)
gnogno35 -
And thank you Padraic
F S - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 61
Todo El Tiempo: 13,859
