Saltar al contenido principal
Asus X502CA-BCL0901D Keyboard Replacement
Qué necesitas
  1. Asus X502CA-BCL0901D Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Flip the laptop over so that it is upside down.
  2. Asus X502CA-BCL0901D Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove the 11 screws from the bottom of the laptop with the Phillips #00 screwdriver.
    • All the screws are 20 mm in diameter. The 4 screws that are furthest from the hinge are 50 mm long, the other 7 are 90 mm long.
  3. Asus X502CA-BCL0901D Keyboard Replacement: paso 3, imagen 1 de 2 Asus X502CA-BCL0901D Keyboard Replacement: paso 3, imagen 2 de 2
    • Use the Plastic Opening Tool to pry the keyboard assembly away from the rest of the laptop.
    • Take care not to lift the keyboard assembly to far away from the laptop as there are short cables that need to be disconnected first.
  4. Asus X502CA-BCL0901D Keyboard Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • While lifting the keyboard assembly, use the tweezers to gently remove the keyboard cable and the touch pad cable by pulling the wires away from the laptop base. Both cables must be gently but firmly pulled towards you for safe removal.
  5. Asus X502CA-BCL0901D Keyboard Replacement: paso 5, imagen 1 de 2 Asus X502CA-BCL0901D Keyboard Replacement: paso 5, imagen 2 de 2
    • Lift the keyboard assembly away from the remainder of the laptop.
Conclusión
Gregory Browne
Miembro Desde 10/19/17
501 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 800
