Saltar al contenido principal
Asus X501A-RH31 Motherboard Replacement
Qué necesitas
  1. Asus X501A-RH31 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Motherboard Replacement: paso 2, imagen 1 de 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Motherboard Replacement: paso 3, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement: paso 3, imagen 2 de 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Motherboard Replacement, Keyboard: paso 4, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Motherboard Replacement: paso 5, imagen 1 de 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Motherboard Replacement: paso 6, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement: paso 6, imagen 2 de 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Motherboard Replacement: paso 7, imagen 1 de 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Motherboard Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Motherboard Replacement, Fan: paso 9, imagen 1 de 1
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 Motherboard Replacement: paso 10, imagen 1 de 1
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 Motherboard Replacement: paso 11, imagen 1 de 3 Asus X501A-RH31 Motherboard Replacement: paso 11, imagen 2 de 3 Asus X501A-RH31 Motherboard Replacement: paso 11, imagen 3 de 3
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
  12. Asus X501A-RH31 Motherboard Replacement, Motherboard: paso 12, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement, Motherboard: paso 12, imagen 2 de 2
    • Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
    • The six screws are 4.2 mm long, 5 mm in diameter.
  13. Asus X501A-RH31 Motherboard Replacement: paso 13, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement: paso 13, imagen 2 de 2
    Comprar
    • Unlatch the data cable by using tweezers to lift the white tab and release the cable.
  14. Asus X501A-RH31 Motherboard Replacement: paso 14, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement: paso 14, imagen 2 de 2
    • Remove the cable on the left side of the motherboard.
    • Use tweezers to pull the white tab up in order to release this cable.
  15. Asus X501A-RH31 Motherboard Replacement: paso 15, imagen 1 de 1
    • On the left side is a small piece of the motherboard. Unscrew the two screws holding this piece down with the Phillips #00 screwdriver.
    • The two screws are 6 mm long, 4.2 mm in diameter.
  16. Asus X501A-RH31 Motherboard Replacement: paso 16, imagen 1 de 3 Asus X501A-RH31 Motherboard Replacement: paso 16, imagen 2 de 3 Asus X501A-RH31 Motherboard Replacement: paso 16, imagen 3 de 3
    • Release the connector cable on the back right side of the motherboard.
    • Peel off the tape with tweezers so that the cable can be released.
    • Using the black plastic spudger, push the back half of the cable towards the screen.
  17. Asus X501A-RH31 Motherboard Replacement: paso 17, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement: paso 17, imagen 2 de 2
    • Grip the motherboard firmly and pull the board leftward and upwards so that the ports on the right side escape their frames.
  18. Asus X501A-RH31 Motherboard Replacement: paso 18, imagen 1 de 2 Asus X501A-RH31 Motherboard Replacement: paso 18, imagen 2 de 2
    • On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
    • Unscrew the two screws using the Phillips #00 screwdriver.
    • These screws are 3 mm in length, 3.5 mm in diameter.
    • Pull the connector downwards and out.
Conclusión
Una persona más ha completado esta guía.
Romana Hruby
Miembro Desde 10/20/17
587 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,158
