Saltar al contenido principal
Asus X501A-RH31 Keyboard Replacement
Qué necesitas
  1. Asus X501A-RH31 Keyboard  Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Keyboard  Replacement: paso 2, imagen 1 de 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Keyboard  Replacement: paso 3, imagen 1 de 2 Asus X501A-RH31 Keyboard  Replacement: paso 3, imagen 2 de 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Keyboard  Replacement, Keyboard: paso 4, imagen 1 de 2 Asus X501A-RH31 Keyboard  Replacement, Keyboard: paso 4, imagen 2 de 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Keyboard  Replacement: paso 5, imagen 1 de 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Keyboard  Replacement: paso 6, imagen 1 de 2 Asus X501A-RH31 Keyboard  Replacement: paso 6, imagen 2 de 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Keyboard  Replacement: paso 7, imagen 1 de 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Keyboard  Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
Conclusión
Una persona más ha completado esta guía.
Romana Hruby
Miembro Desde 10/20/17
587 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,144
