Saltar al contenido principal
Asus X401A Trackpad Replacement
Qué necesitas
  1. Asus X401A Trackpad Replacement, Trackpad: paso 1, imagen 1 de 2 Asus X401A Trackpad Replacement, Trackpad: paso 1, imagen 2 de 2
    • Working on your device while it is turned on may result in electric shock. Shut down and unplug your device before starting repair.
    • Turn over laptop and remove the battery for ease of replacement.
  2. Asus X401A Trackpad Replacement: paso 2, imagen 1 de 3 Asus X401A Trackpad Replacement: paso 2, imagen 2 de 3 Asus X401A Trackpad Replacement: paso 2, imagen 3 de 3
    • Use a Phillips Head #1 screwdriver to unscrew the eight 3mm screws.
    • Use a Phillips head #1 screwdriver to unscrew the two 4mm screws.
  3. Asus X401A Trackpad Replacement: paso 3, imagen 1 de 3 Asus X401A Trackpad Replacement: paso 3, imagen 2 de 3 Asus X401A Trackpad Replacement: paso 3, imagen 3 de 3
    • Use a plastic spudger to pry off the front cover of the keyboard.
    • Do not jerk the keyboard cover off as there are ribbon cables that need to be disconnected.
    • When reassembling, there will be loud clicking to indicate you have snapped the keyboard cover into place correctly.
  4. Asus X401A Trackpad Replacement: paso 4, imagen 1 de 2 Asus X401A Trackpad Replacement: paso 4, imagen 2 de 2
    • Removing the white wiring from the trackpad.
    • Continue removing the wire until you get to the end.
    • Fold up the latch on the where the cable meets the motherboard.
    • Be careful not to damage any wiring during this process.
    • When reassembling, slide ribbon cable in up to black line.
  5. Asus X401A Trackpad Replacement: paso 5, imagen 1 de 2 Asus X401A Trackpad Replacement: paso 5, imagen 2 de 2
    • Use a spudger to lift the ZIF connector tabs up.
    • Remove the black and the white ribbon cable.
    • Remove the entire keyboard covering.
  6. Asus X401A Trackpad Replacement: paso 6, imagen 1 de 1
    • Lay the keyboard cover down with the keys facing down. This component contains the track pad. You will be working with this component until you reassemble.
  7. Asus X401A Trackpad Replacement: paso 7, imagen 1 de 1
    • Begin peeling up the clear tape located on top of the band aid seal.
  8. Asus X401A Trackpad Replacement: paso 8, imagen 1 de 2 Asus X401A Trackpad Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Using a PH0 Phillips Screwdriver, remove the two screws located within the circles of the band aid seal.
    • These screws are small. Be sure to place them on your magnetic mat.
  9. Asus X401A Trackpad Replacement: paso 9, imagen 1 de 2 Asus X401A Trackpad Replacement: paso 9, imagen 2 de 2
    • Begin peeling back the band aid tape. Use the plastic spudger if necessary. This will allow you to free up the trackpad.
    • Only pull the tape back to the seam and no further.
  10. Asus X401A Trackpad Replacement: paso 10, imagen 1 de 2 Asus X401A Trackpad Replacement: paso 10, imagen 2 de 2
    • Remove the faulty trackpad gently.
Conclusión
2 personas más completaron esta guía.
Lesley Pfening
Miembro Desde 02/07/17
360 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-4, Wilder Spring 2017 Miembro de Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 1,061
