Introducción
If you find your computer running slow, it may be time to upgrade your RAM. Having more RAM will give your computer more zip for activities such as browsing the internet. It is important to turn off and unplug your laptop before starting this guide. The screws you remove in this repair are small, so be sure to have a magnetic mat handy!
Qué necesitas
Using a Phillips Head #1 screwdriver, unscrew ten screws from the back of the laptop.
Eight screws are 3mm.
Two screws are 4mm. Place screws on magnetic mat.
There are two ribbon cables connecting the keyboard to the motherboard.
The larger cable is a ZIF (Zero Insertion Force) cable. As the name implies, you do not need to use force to insert or disconnect this cable. Disconnect this ribbon cable by unlocking the holding latch and pulling out gently.
The smaller ribbon cable requires nothing more than pulling it out gently.
4 personas más completaron esta guía.
