Saltar al contenido principal
Asus X401A Processor Replacement
Qué necesitas
  1. Asus X401A Processor Replacement, Processor: paso 1, imagen 1 de 2 Asus X401A Processor Replacement, Processor: paso 1, imagen 2 de 2
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: paso 2, imagen 1 de 3 Asus X401A Processor Replacement: paso 2, imagen 2 de 3 Asus X401A Processor Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: paso 3, imagen 1 de 3 Asus X401A Processor Replacement: paso 3, imagen 2 de 3 Asus X401A Processor Replacement: paso 3, imagen 3 de 3
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: paso 4, imagen 1 de 3 Asus X401A Processor Replacement: paso 4, imagen 2 de 3 Asus X401A Processor Replacement: paso 4, imagen 3 de 3
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: paso 5, imagen 1 de 1
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: paso 6, imagen 1 de 1
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: paso 7, imagen 1 de 2 Asus X401A Processor Replacement: paso 7, imagen 2 de 2
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: paso 8, imagen 1 de 1
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: paso 9, imagen 1 de 3 Asus X401A Processor Replacement: paso 9, imagen 2 de 3 Asus X401A Processor Replacement: paso 9, imagen 3 de 3
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: paso 10, imagen 1 de 2 Asus X401A Processor Replacement: paso 10, imagen 2 de 2
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: paso 11, imagen 1 de 2 Asus X401A Processor Replacement: paso 11, imagen 2 de 2
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: paso 12, imagen 1 de 3 Asus X401A Processor Replacement: paso 12, imagen 2 de 3 Asus X401A Processor Replacement: paso 12, imagen 3 de 3
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
Conclusión
2 personas más completaron esta guía.
Tyler Stiles
Miembro Desde 02/07/17
152 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-4, Wilder Spring 2017 Miembro de Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 Miembros
5 Guías creadas
Un comentario
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,830
