Saltar al contenido principal
Asus X200MA Trackpad Replacement
Qué necesitas
  1. Asus X200MA Trackpad Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Trackpad Replacement: paso 2, imagen 1 de 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Trackpad Replacement: paso 3, imagen 1 de 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Trackpad Replacement, Trackpad: paso 4, imagen 1 de 2 Asus X200MA Trackpad Replacement, Trackpad: paso 4, imagen 2 de 2
    • Use the spudger to lift up and remove the black plastic covering.
  5. Asus X200MA Trackpad Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  6. Asus X200MA Trackpad Replacement, Mouse: paso 6, imagen 1 de 1
    • Remove wider blue strip with tweezers.
  7. Asus X200MA Trackpad Replacement: paso 7, imagen 1 de 1
    • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
  8. Asus X200MA Trackpad Replacement: paso 8, imagen 1 de 1
    • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
  9. Asus X200MA Trackpad Replacement: paso 9, imagen 1 de 2 Asus X200MA Trackpad Replacement: paso 9, imagen 2 de 2
    • Use metal spudger to get in between mouse pad and keyboard and lift off.
Conclusión
Una persona más ha completado esta guía.
Vanessa Garcia
Miembro Desde 01/22/15
1,763 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-24, Maness Winter 2015 Miembro de Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 2,123
