Saltar al contenido principal
Asus X200MA Speaker Replacement
Qué necesitas
  1. Asus X200MA Speaker Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Speaker Replacement: paso 2, imagen 1 de 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Speaker Replacement: paso 3, imagen 1 de 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Disconnect the gold cap that connects to a black wire using the metal spudger.
  5. Asus X200MA Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the plastic component from the clip by gently pulling it back.
  6. Asus X200MA Speaker Replacement: paso 6, imagen 1 de 2 Asus X200MA Speaker Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use the tweezers to free the speaker from the plastic clips.
    • Use a finger to lift the speaker and break the bond between the adhesive on the base plate and the speaker.
  7. Asus X200MA Speaker Replacement: paso 7, imagen 1 de 3 Asus X200MA Speaker Replacement: paso 7, imagen 2 de 3 Asus X200MA Speaker Replacement: paso 7, imagen 3 de 3
    • Use the tweezers to carefully lift the wires from the plastic clips.
  8. Asus X200MA Speaker Replacement: paso 8, imagen 1 de 2 Asus X200MA Speaker Replacement: paso 8, imagen 2 de 2
    • Use the metal tweezers to free the speaker from the plastic clips.
    • Use the metal spudger to break the bond between the base plate adhesive and the speaker.
    • Lift the speakers and remove them from the base plate.
Conclusión
To reassemble your device, follow these instructions in reverse [#|order].
Alli Krininger
Miembro Desde 11/11/19
391 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G4, Stella Fall 2019 Miembro de IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
Miembros de 4
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 567
