Saltar al contenido principal
Asus X200MA Motherboard Replacement
Qué necesitas
  1. Asus X200MA Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: paso 2, imagen 1 de 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Motherboard Replacement, Battery: paso 4, imagen 1 de 1
  5. Asus X200MA Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Motherboard Replacement: paso 6, imagen 1 de 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Motherboard Replacement: paso 8, imagen 1 de 1
    • Slide the battery up and out.
  9. Asus X200MA Motherboard Replacement, Fan: paso 9, imagen 1 de 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  10. Asus X200MA Motherboard Replacement: paso 10, imagen 1 de 2 Asus X200MA Motherboard Replacement: paso 10, imagen 2 de 2
    • Unplug the set of wires located at bottom corner on fan.
  11. Asus X200MA Motherboard Replacement: paso 11, imagen 1 de 2 Asus X200MA Motherboard Replacement: paso 11, imagen 2 de 2
    • Lift up and out to completely the remove fan component.
  12. Asus X200MA Motherboard Replacement, Motherboard: paso 12, imagen 1 de 1
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  13. Asus X200MA Motherboard Replacement: paso 13, imagen 1 de 2 Asus X200MA Motherboard Replacement: paso 13, imagen 2 de 2
    • Pull back the blue ribbon, freeing it from the latch.
  14. Asus X200MA Motherboard Replacement: paso 14, imagen 1 de 3 Asus X200MA Motherboard Replacement: paso 14, imagen 2 de 3 Asus X200MA Motherboard Replacement: paso 14, imagen 3 de 3
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
Conclusión
2 personas más completaron esta guía.
Alli Krininger
Miembro Desde 11/11/19
391 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G4, Stella Fall 2019 Miembro de IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 1,214
