Saltar al contenido principal
Asus X200MA Hard Drive Replacement
Qué necesitas
  1. Asus X200MA Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Hard Drive Replacement: paso 2, imagen 1 de 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Hard Drive Replacement: paso 3, imagen 1 de 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Remove the black foam and adhesive located on top of the hard drive.
  5. Asus X200MA Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  6. Asus X200MA Hard Drive Replacement: paso 6, imagen 1 de 1
    • Slide out the hard drive
Conclusión
3 personas más completaron esta guía.
Vanessa Garcia
Miembro Desde 01/22/15
1,796 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-24, Maness Winter 2015 Miembro de Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
Miembros de 4
8 Guías creadas
2Guía Comentarios
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Contestar
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 27
Todo El Tiempo: 9,481
