Saltar al contenido principal
Asus X200CA-HCL 1104G Speaker Replacement
Qué necesitas
  1. Asus X200CA-HCL 1104G Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Speaker Replacement: paso 2, imagen 1 de 1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Speaker Replacement: paso 3, imagen 1 de 1
    • Unclip the connector that is located above touch screen
  4. Asus X200CA-HCL 1104G Speaker Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the speaker bar that is located beneath the touch screen.
    • Once removed carefully disconnect the clip to the left of the speaker.
Conclusión
Svetlana Pimentel
Miembro Desde 10/17/17
201 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 288
