Saltar al contenido principal
Asus X200CA-HCL 1104G Headphone Jack Replacement
Qué necesitas
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: paso 4, imagen 1 de 2 Asus X200CA-HCL 1104G Headphone Jack Replacement: paso 4, imagen 2 de 2
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
Conclusión
Samantha Wahl
Miembro Desde 10/17/17
301 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Miembro de UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 146
