Partes
No se requieren partes.
Using the Phillips 1 screwdriver, remove the laptop's back panel.
  • Using the Phillips 1 screwdriver, remove the laptop's back panel.
  • The parts you see underneath that panel are called the laptop's "internals".
Agregar Comentario
Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
Agregar Comentario
  • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
Agregar Comentario
  • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
  • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
  • With the screws removed, the audio board can be easily lifted out.
Agregar Comentario
Conclusión
Samantha Wahl
Miembro Desde 17/10/17
301 Reputación
3 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 30
