Saltar al contenido principal
Asus X200CA-HCL 1104G Battery Replacement
Qué necesitas
  1. Asus X200CA-HCL 1104G Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Battery Replacement: paso 2, imagen 1 de 1
    • The battery will be easily visible towards to top of the internals. It is a long, black rectangle marked "Li-ion". Notice that the battery is currently secured by three screws. We will need to unscrew them in order to remove the battery.
  3. Asus X200CA-HCL 1104G Battery Replacement: paso 3, imagen 1 de 1
    • You will notice that there are two gold screws and one silver screw holding the battery in place. Using the Phillips 1 screwdriver, remove the silver screw.
    • For the gold screws, pliers may be necessary. Be careful not to cut yourself on them; they can be finicky.
    • From here, the battery will lift easily out of the laptop.
Conclusión
Samantha Wahl
Miembro Desde 10/17/17
301 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 421
