Saltar al contenido principal
Asus X200CA Motherboard and RAM Replacement
Qué necesitas
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: paso 1, imagen 1 de 2 Asus X200CA Motherboard and RAM Replacement, Keyboard: paso 1, imagen 2 de 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: paso 2, imagen 1 de 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: paso 3, imagen 1 de 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: paso 4, imagen 1 de 1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: paso 5, imagen 1 de 2 Asus X200CA Motherboard and RAM Replacement: paso 5, imagen 2 de 2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: paso 6, imagen 1 de 2 Asus X200CA Motherboard and RAM Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: paso 7, imagen 1 de 2 Asus X200CA Motherboard and RAM Replacement: paso 7, imagen 2 de 2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: paso 8, imagen 1 de 1
    • Lift the motherboard/RAM out from the frame.
Conclusión
7 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G2, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 100
Todo El Tiempo: 8,842
