Saltar al contenido principal
Asus W2W-A1 Hard Drive Replacement
Qué necesitas
  1. Asus W2W-A1 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Before disassembly, make sure the laptop is powered off and the battery is disconnected.
    • Remove the two screws (size?) on the lower panel at the bottom of the laptop (identify tool to use).
  2. Asus W2W-A1 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Grab the panel and lift upwards while pulling towards yourself.
  3. Asus W2W-A1 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the 3 4 mm Phillips upper screws holding the hard drive down.
  4. Asus W2W-A1 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Pull the hard drive towards yourself to disconnect it from the laptop.
  5. Asus W2W-A1 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Lift the hard drive upwards to remove it from the laptop.
Conclusión
Nolan Schock
Miembro Desde 04/14/14
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-29, Maness Spring 2014 Miembro de Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 275
