Saltar al contenido principal
Introducción
The battery is the main source of power to the computer. Often times batteries will lose charge and need to be replaced. If the laptop won't turn on without the power cable, use this guide to replace the battery.
Partes
No se especificaron partes.
  1. Before doing a replacement, make sure the laptop is fully shut off. Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
    • Before doing a replacement, make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Pry open the back casing using the opening tool along the side crevice. Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Using the JIS #0 Screwdriver, remove the five 5.0 mm screws that hold down the battery. Using the JIS #0 Screwdriver, remove the five 5.0 mm screws that hold down the battery.
    • Using the JIS #0 Screwdriver, remove the five 5.0 mm screws that hold down the battery.
  5. Disconnect the cable connected to the motherboard. To remove, lift the ends using the opening tool.
    • Disconnect the cable connected to the motherboard.
    • To remove, lift the ends using the opening tool.
Conclusión
Equipo
USF Tampa, Team S5-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 172
