Introducción
If your track pad has become unresponsive, it may be time to replace it. This guide will show you how to replace your track pad.
Qué necesitas
Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
Remove the four 4.0 mm Phillips #1 screws shown.
Remove the two 5.0 mm Phillips #1 screws shown.
Remove the three 3.0 mm Phillips #1 screws shown.
