Saltar al contenido principal
Asus Vivobook Q301LA-BHI5T02 Battery Replacement
Qué necesitas
  1. Asus Vivobook Q301LA-BHI5T02 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 2, imagen 1 de 2 Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 3, imagen 1 de 3 Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 3, imagen 2 de 3 Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 3, imagen 3 de 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 4, imagen 1 de 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Battery Replacement, Battery: paso 5, imagen 1 de 2 Asus Vivobook Q301LA-BHI5T02 Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
  6. Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 6, imagen 1 de 2 Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 6, imagen 2 de 2
    • Unplug the battery connector from the mother board.
  7. Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 7, imagen 1 de 2 Asus Vivobook Q301LA-BHI5T02 Battery Replacement: paso 7, imagen 2 de 2
    • Gently remove the battery from the slot.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S10-G3, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G3, Thompson Fall 2017
USFT-THOMPSON-F17S10G3
4 Miembros
6 Guías creadas
Un comentario
Outstanding instructions in replacing this battery. Very easy. Thanks!!
Richard Robinson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 2,517
