Saltar al contenido principal
Asus Vivobook Max X541SA-PD0703X Motherboard Replacement
Qué necesitas
  1. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 3, imagen 1 de 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 3, imagen 2 de 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 3, imagen 3 de 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 4, imagen 1 de 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 4, imagen 2 de 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 6, imagen 1 de 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 6, imagen 2 de 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Disc Drive: paso 8, imagen 1 de 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: paso 9, imagen 1 de 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: paso 9, imagen 2 de 2
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 10, imagen 1 de 1
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 11, imagen 1 de 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 11, imagen 2 de 2
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 14, imagen 1 de 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 14, imagen 2 de 2
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: paso 15, imagen 1 de 1
    • Pull the motherboard to the right and lift up.
Conclusión
2 personas más completaron esta guía.
Hetvi Mehta
Miembro Desde 02/22/18
781 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G4, Cagle Spring 2018 Miembro de USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 31
Todo El Tiempo: 3,139
