Saltar al contenido principal
Asus Vivobook Flip 14 TP410U LCD Assembly Replacement
Qué necesitas
  1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement, LCD Assembly: paso 1, imagen 1 de 1
    • Turn off the power and disconnected the AC cable from the laptop.
  2. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: paso 2, imagen 1 de 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: paso 2, imagen 2 de 2
    • Remove the rubber covers for the two screws located at the bottom of the screen.
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws outlined in the image.
  3. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: paso 3, imagen 1 de 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: paso 3, imagen 2 de 2
    • Excessive force may cause damage to connections.
    • Rotate the screen 360 degrees for ease of access.
    • Place the opening tool at the corner of where the screen meets the base of the laptop.
    • Pry open the screen along the edge until it is completely off the front cover.
    • Disconnect each appropriate connector while opening up the laptop.
  4. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: paso 4, imagen 1 de 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: paso 4, imagen 2 de 2
    • Excessive force should avoided since damage may accrue.
    • Remove the cable that connects to the touch display, front camera, and motherboard.
    • Remove each piece of tape that holds down each cable.
  5. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: paso 5, imagen 1 de 1
    • Have the new LCD display fully unboxed and ready to be used.
    • Remove the old LCD display.
    • The touch screen sensor is extremely fragile, make sure to not put excessive force on the cable while assembling.
Conclusión
Una persona más ha completado esta guía.
Dominic Bento
Miembro Desde 03/22/22
305 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 45
Todo El Tiempo: 810
