Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Asus VivoTab Smart Battery Replacement
Qué necesitas
  1. Asus VivoTab Smart Battery Replacement, Battery: paso 1, imagen 1 de 3 Asus VivoTab Smart Battery Replacement, Battery: paso 1, imagen 2 de 3 Asus VivoTab Smart Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Battery Replacement: paso 2, imagen 1 de 3 Asus VivoTab Smart Battery Replacement: paso 2, imagen 2 de 3 Asus VivoTab Smart Battery Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
    • Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
  3. Asus VivoTab Smart Battery Replacement: paso 3, imagen 1 de 3 Asus VivoTab Smart Battery Replacement: paso 3, imagen 2 de 3 Asus VivoTab Smart Battery Replacement: paso 3, imagen 3 de 3
    • The Philips #00 Screwdriver listed in the recommended tools will fit all the screws.
    • Remove the tape covering the areas marked by the black arrows
    • Remove two 3.7 mm Phillips #00 screws
    • Remove eleven 2.7 mm Phillips #00 screws
  4. Asus VivoTab Smart Battery Replacement: paso 4, imagen 1 de 2 Asus VivoTab Smart Battery Replacement: paso 4, imagen 2 de 2
    • Be careful not to damage the speaker wire.
    • Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
    • Lift up on the speaker with your fingers to remove it.
  5. Asus VivoTab Smart Battery Replacement: paso 5, imagen 1 de 1
    • Gently lift the battery pressure plate off of the motherboard.
  6. Asus VivoTab Smart Battery Replacement: paso 6, imagen 1 de 2 Asus VivoTab Smart Battery Replacement: paso 6, imagen 2 de 2
    • Use tweezers to separate the battery tray from the device
    • Lift the battery tray from the device using your hands.
  7. Asus VivoTab Smart Battery Replacement: paso 7, imagen 1 de 1
    • The battery is secured to the tray by a strong adhesive. Take care not to bend the tray when removing the battery.
    • Detach the battery from the tray by pulling the battery up from the tray with your hands.
    • If it is very difficult to lift the battery from the tray, you can use a blow dryer to heat the back side of the tray. This will weaken the adhesive and make it easier to remove.
Conclusión
4 personas más completaron esta guía.
Zach Hatten
Miembro Desde 10/06/16
563 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 2-4, Sullivan Fall 2016 Miembro de USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
Miembros de 4
5 Guías creadas
2Guía Comentarios
Hi
So where is the next step ?!
Albert einstein - Contestar Compartir
Hi
Please answer to me. This is so
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 31
Ultimos 30 días: 94
Todo El Tiempo: 3,834
