Saltar al contenido principal
Asus VivoTab RT TF600T Speaker Replacement
Qué necesitas
  1. Asus VivoTab RT TF600T Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Asus VivoTab RT TF600T Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Asus VivoTab RT TF600T Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Make sure the tablet is turned off.
    • Remove the tablet from the attached keyboard.
    • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
  2. Asus VivoTab RT TF600T Speaker Replacement: paso 2, imagen 1 de 3 Asus VivoTab RT TF600T Speaker Replacement: paso 2, imagen 2 de 3 Asus VivoTab RT TF600T Speaker Replacement: paso 2, imagen 3 de 3
    • Rotate the device 180°, and remove the two 1.59 mm #000 screws at the bottom of the device.
    • Use the Phillips screwdriver size PH000 to remove the two 1.59 mm #000 screws.
  3. Asus VivoTab RT TF600T Speaker Replacement: paso 3, imagen 1 de 2 Asus VivoTab RT TF600T Speaker Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to help detach the screen from the back panel.
    • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
    • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
  4. Asus VivoTab RT TF600T Speaker Replacement: paso 4, imagen 1 de 2 Asus VivoTab RT TF600T Speaker Replacement: paso 4, imagen 2 de 2
    • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
    • Lift the screen to view the inside of the tablet.
  5. Asus VivoTab RT TF600T Speaker Replacement: paso 5, imagen 1 de 2 Asus VivoTab RT TF600T Speaker Replacement: paso 5, imagen 2 de 2
    • Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
    • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
  6. Asus VivoTab RT TF600T Speaker Replacement: paso 6, imagen 1 de 3 Asus VivoTab RT TF600T Speaker Replacement: paso 6, imagen 2 de 3 Asus VivoTab RT TF600T Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the yellow tape covering the end of the cables.
  7. Asus VivoTab RT TF600T Speaker Replacement: paso 7, imagen 1 de 2 Asus VivoTab RT TF600T Speaker Replacement: paso 7, imagen 2 de 2
    • After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
    • Use the plastic opening tool to push in the levers.
  8. Asus VivoTab RT TF600T Speaker Replacement: paso 8, imagen 1 de 3 Asus VivoTab RT TF600T Speaker Replacement: paso 8, imagen 2 de 3 Asus VivoTab RT TF600T Speaker Replacement: paso 8, imagen 3 de 3
    • With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
  9. Asus VivoTab RT TF600T Speaker Replacement: paso 9, imagen 1 de 1
    • Lift the screen upwards to remove.
  10. Asus VivoTab RT TF600T Speaker Replacement: paso 10, imagen 1 de 2 Asus VivoTab RT TF600T Speaker Replacement: paso 10, imagen 2 de 2
    • Turn the tablet clockwise, so the speaker is facing the right.
    • Use the nylon or metal spudger to pry the battery from the back panel.
  11. Asus VivoTab RT TF600T Speaker Replacement: paso 11, imagen 1 de 2 Asus VivoTab RT TF600T Speaker Replacement: paso 11, imagen 2 de 2
    • Remove two 0.79 mm #00 screws from the speaker with a Phillips screwdriver size #00.
  12. Asus VivoTab RT TF600T Speaker Replacement: paso 12, imagen 1 de 2 Asus VivoTab RT TF600T Speaker Replacement: paso 12, imagen 2 de 2
    • Remove the speaker with the plastic opening tool.
Conclusión
Una persona más ha completado esta guía.
Joseph C Reneau
Miembro Desde 10/15/15
276 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 282
