Introducción
Use this guide to replace the DC board in your Asus VivoTab Note 8. The DC board is the board with the micro USB port and the 3.5mm headphone jack. You will need a #000 Phillips screwdriver and a plastic opening tool to complete this repair. It will take about 10 minutes to complete and is a moderate difficulty.
Herramientas
Partes
No se especificaron partes.
Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
Unplug the battery from the motherboard.
Lodge something (a fingernail works fine) under the connecting piece and apply a force straight up and perpendicular to the back of the device.
