Introducción
The hard drive is where almost every file in the computer exists. This component can fail if the computer is dropped or if a virus or the operating system corrupts the files located on the drive. Be aware that dropping the drive or placing it near a strong magnet may result in the permanent loss of files.
Qué necesitas
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
