Saltar al contenido principal
Asus VivoBook X202E-DB21T Hard Drive Replacement
Qué necesitas
  1. Asus VivoBook X202E-DB21T Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus VivoBook X202E-DB21T Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 2, imagen 1 de 2 Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 2, imagen 2 de 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 3, imagen 1 de 2 Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Asus VivoBook X202E-DB21T Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 7, imagen 1 de 2 Asus VivoBook X202E-DB21T Hard Drive Replacement: paso 7, imagen 2 de 2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 1,058
