Saltar al contenido principal
Introducción
You may need to replace the battery if it does not hold a charge or the laptop does not turn on. Be aware that this battery is a Lithium-Polymer battery and can explode if punctured.
  1. Flip the device such that the labels are on top. Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Remove the back cover by gently prying with a spudger. Remove the back cover by gently prying with a spudger.
    • Remove the back cover by gently prying with a spudger.
  3. Remove the eight 5mm screws using a Phillips #1 screwdriver. Do not puncture the battery.
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Disconnect the battery ribbon cable from the motherboard.
    • Disconnect the battery ribbon cable from the motherboard.
  5. Remove the battery from the laptop.
    • Remove the battery from the laptop.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 168
