Saltar al contenido principal
Asus VivoBook S200E-RHI3T73 Touchpad Replacement
Qué necesitas
  1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: paso 1, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: paso 1, imagen 2 de 2
    • In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
    • There are five 80mm screws.
    • There are four 50mm screws.
    • Pull the back lid off of the laptop using your fingers.
  2. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: paso 2, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: paso 2, imagen 2 de 2
    • There should be a total of twelve 50mm screws when removing the battery.
    • The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
  3. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: paso 3, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
    • Disconnect the LED ribbon wires using a spudger to lift the clamp.
  4. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: paso 4, imagen 1 de 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: paso 4, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
    • Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Pull the touch pad up and towards the battery to remove it from the laptop.
Conclusión
Equipo
IUPUI, Team S9-G9, Wilson Spring 2019 Miembro de IUPUI, Team S9-G9, Wilson Spring 2019
IUPUI-WILSON-S19S9G9
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 761
