Introducción
This guide shows how to replace the Wi-Fi chip from the motherboard of the Asus VivoBook. The Wi-Fi chip allows the laptop to wirelessly connect to internet. In rare cases, the Wi-Fi chip may need to be replaced if a power surge fries the chip or the chip itself is defective.
  1. Before doing a repair or replacement make sure the laptop is fully shut off. Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Insert the flat edge of the opening tool in between the back casing to remove the back casing. Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Use a JIS #0 Screwdriver to remove the one 3.0 mm screw. Use a JIS #0 Screwdriver to remove the one 3.0 mm screw.
    • Use a JIS #0 Screwdriver to remove the one 3.0 mm screw.
  5. Disconnect the black and white wires that provide power and data transfer to the Wi-Fi chip. Disconnect the black and white wires that provide power and data transfer to the Wi-Fi chip.
    • Disconnect the black and white wires that provide power and data transfer to the Wi-Fi chip.
Conclusión
Una persona más ha completado esta guía.
Deric Wright
Miembro Desde 14/02/18
588 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S5-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 67
