Saltar al contenido principal
Asus VivoBook Q302LA-BHI3T09 Display Replacement
Qué necesitas
  1. Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: paso 1, imagen 1 de 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: paso 1, imagen 2 de 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 2, imagen 1 de 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 2, imagen 2 de 2
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 3, imagen 1 de 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 3, imagen 2 de 2
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 4, imagen 1 de 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 4, imagen 2 de 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 4, imagen 3 de 3
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 5, imagen 1 de 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 5, imagen 2 de 2
    • Disconnect the white and black wires attached to the Wi-Fi chip.
  6. Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 6, imagen 1 de 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 6, imagen 2 de 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 6, imagen 3 de 3
    • Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
  7. Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 7, imagen 1 de 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 7, imagen 2 de 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: paso 7, imagen 3 de 3
    • Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
Conclusión
Deric Wright
Miembro Desde 02/14/18
636 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S5-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 262
