Saltar al contenido principal
Asus VivoBook Q200E-BSI3T08 Battery Replacement
Qué necesitas
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 3, imagen 1 de 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 5, imagen 1 de 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 5, imagen 2 de 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 5, imagen 3 de 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 6, imagen 1 de 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: paso 6, imagen 2 de 2
    • Now just lift the battery out of place.
Conclusión
14 personas más completaron esta guía.
Maxim
Miembro Desde 01/21/15
462 Reputación
1 Guía escrita
Equipo
UWT Liner: Group 6 Miembro de UWT Liner: Group 6
Community
3 Miembros
1 Guía escrita
2 comentarios
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Contestar
Great guide. Thanks!
weston.fisher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 7,333
