Saltar al contenido principal
Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement
Qué necesitas
  1. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, Battery: paso 1, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, Battery: paso 1, imagen 2 de 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 3, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 3, imagen 2 de 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 4, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 4, imagen 2 de 2
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 5, imagen 1 de 1
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, WLAN (Wireless Chip): paso 6, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, WLAN (Wireless Chip): paso 6, imagen 2 de 2
    • Remove one 5mm screw using a PH0 Philips screwdriver.
  7. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 7, imagen 1 de 1
    • Remove the cable by lifting upwards with a pair of tweezers.
  8. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: paso 8, imagen 1 de 1
    • Remove the WLAN chip by pulling out parallel to the surface.
Conclusión
Bryann Tan
Miembro Desde 09/25/16
877 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 16-2, Eyestone Fall 2016 Miembro de USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 197
