Saltar al contenido principal
Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement
Qué necesitas
  1. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 3, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 4, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Remove four 4mm screws using a Phillips 0 screwdriver.
  7. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Pull out hard drive bracket towards the edge of the laptop.
  8. Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 8, imagen 1 de 3 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 8, imagen 2 de 3 Asus VivoBook Q200E-BHI3T45 Hard Drive Replacement: paso 8, imagen 3 de 3
    • Remove two 3mm screws using a Phillips 0 screwdriver from each sides of the hard drive bracket. The bracket should fall off after removal.
Conclusión
6 personas más completaron esta guía.
Bryann Tan
Miembro Desde 09/25/16
877 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 16-2, Eyestone Fall 2016 Miembro de USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 5,468
