Saltar al contenido principal
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
Qué necesitas
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 2, imagen 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 2, imagen 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 3, imagen 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 3, imagen 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 3, imagen 3 de 3
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 4, imagen 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 4, imagen 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 4, imagen 3 de 3
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 5, imagen 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 5, imagen 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 5, imagen 3 de 3
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 6, imagen 1 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 6, imagen 2 de 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: paso 6, imagen 3 de 3
    • Carefully remove the battery using a plastic opening tool.
Conclusión
Una persona más ha completado esta guía.
Vivek Rana
Miembro Desde 09/11/21
169 Reputación
1 Guía escrita
Equipo
Un comentario
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 75
Todo El Tiempo: 2,087
