Saltar al contenido principal
Asus V6800V Wireless Card Replacement
Qué necesitas
  1. Asus V6800V Wireless Card Replacement, Battery: paso 1, imagen 1 de 2 Asus V6800V Wireless Card Replacement, Battery: paso 1, imagen 2 de 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Wireless Card Replacement, Wireless Card: paso 2, imagen 1 de 2 Asus V6800V Wireless Card Replacement, Wireless Card: paso 2, imagen 2 de 2
    • Remove the six screws highlighted on the picture.
    • Once the screws are removed, pry open the panel with the pry tool.
    • It should now look like this.
  3. Asus V6800V Wireless Card Replacement: paso 3, imagen 1 de 2 Asus V6800V Wireless Card Replacement: paso 3, imagen 2 de 2
    • After removing that panel, locate the screw on the right as highlighted.
    • Remove that screw.
    • Pry open the side panel with the small prying tool as shown.
    • That panel should pop off and the wireless card will now be easily visible.
  4. Asus V6800V Wireless Card Replacement: paso 4, imagen 1 de 1
    • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
    • Repeat for the other one.
    • Place the gold connectors aside.
  5. Asus V6800V Wireless Card Replacement: paso 5, imagen 1 de 3 Asus V6800V Wireless Card Replacement: paso 5, imagen 2 de 3 Asus V6800V Wireless Card Replacement: paso 5, imagen 3 de 3
    • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
    • Place one finger on each tab and press each to the side away from the wireless card as shown.
    • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
  6. Asus V6800V Wireless Card Replacement: paso 6, imagen 1 de 2 Asus V6800V Wireless Card Replacement: paso 6, imagen 2 de 2
    • To remove the wireless card, pull the card directly out.
    • It should come out with just a little bit of pressure.
    • It should look as shown when removed.
Conclusión
Steven
Miembro Desde 06/24/10
32 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-9, Johann Summer 2010 Miembro de Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 3,850
