Introducción
Use this guide to open the lower case of the Asus V6800V laptop. Opening the lower case will allow access to most of the laptops internals, where further repairs can be made if needed.
Be careful when removing the various connections. Being too rough may result in the need of further repairs.
Make sure your device is powered off before beginning.
Qué necesitas
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
