Saltar al contenido principal
Asus V6800V Fan Replacement
Qué necesitas
  1. Asus V6800V Fan Replacement, Battery: paso 1, imagen 1 de 2 Asus V6800V Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Fan Replacement, Fan: paso 2, imagen 1 de 2 Asus V6800V Fan Replacement, Fan: paso 2, imagen 2 de 2
    • Use the Phillips #0 to remove the six screws on the back of the device.
    • Gently open the cover using the tab located by the highlighted box.
  3. Asus V6800V Fan Replacement: paso 3, imagen 1 de 2 Asus V6800V Fan Replacement: paso 3, imagen 2 de 2
    • Unplug the wires by pulling straight up on the white connector and away from the computer.
    • Make sure not to pull on the wires (as shown in the second picture). The white connector should pop off with very little force.
  4. Asus V6800V Fan Replacement: paso 4, imagen 1 de 2 Asus V6800V Fan Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #0 to remove the three screws holding the fan in place.
  5. Asus V6800V Fan Replacement: paso 5, imagen 1 de 2 Asus V6800V Fan Replacement: paso 5, imagen 2 de 2
    • Remove the fan from the device.
    • The fan should remove easily.
  6. Asus V6800V Fan Replacement: paso 6, imagen 1 de 2 Asus V6800V Fan Replacement: paso 6, imagen 2 de 2
    • Use a cotton swab or compressed air to blow air from the inside, out to clear dust from the vent or heat sink.
Conclusión
Jong Park
Miembro Desde 06/24/10
114 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 2-9, Johann Summer 2010 Miembro de Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 4,963
