Introducción
Use this guide to replace the display of your Asus V6800V.
Herramientas
Partes
No se requieren partes.
Flip the computer over so that it is upside down.
Slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Unscrew the screws at the bottom of the chassis to remove the top panel.
Once the case is separated, it is relatively easy to replace the display. Just be very careful; new displays can cost several hundred dollars.
First, we need to get the display by itself.
The connector to the display on the back should be removed. Be gentle because these are not replaceable.
There is tape holding the cable to the display. The best method of removing the cable is by gently pulling tape off of the part connected to the display and using that leverage to gently pull down.
To reassemble your device, follow these instructions in reverse order. The display is very sensitive, so do not apply any pressure to the front or back of the display.
Una persona más ha completado esta guía.
