Saltar al contenido principal
Asus V6800V CD/DVD Drive Replacement
Qué necesitas
  1. Asus V6800V CD/DVD Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus V6800V CD/DVD Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: paso 2, imagen 1 de 2 Asus V6800V CD/DVD Drive Replacement, Hard Drive: paso 2, imagen 2 de 2
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: paso 3, imagen 1 de 2 Asus V6800V CD/DVD Drive Replacement: paso 3, imagen 2 de 2
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: paso 4, imagen 1 de 2 Asus V6800V CD/DVD Drive Replacement: paso 4, imagen 2 de 2
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: paso 5, imagen 1 de 2 Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: paso 5, imagen 2 de 2
    • Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
    • Insert a spudger into the hole to carefully push the CD/DVD drive out.
Conclusión
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
Jong Park
Miembro Desde 06/24/10
114 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 2-9, Johann Summer 2010 Miembro de Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 4,260
