Saltar al contenido principal
Asus V500CA-DB51T Hard Drive Replacement
Qué necesitas
  1. Asus V500CA-DB51T Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus V500CA-DB51T Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T Hard Drive Replacement: paso 2, imagen 1 de 2 Asus V500CA-DB51T Hard Drive Replacement: paso 2, imagen 2 de 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T Hard Drive Replacement: paso 3, imagen 1 de 1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T Hard Drive Replacement: paso 4, imagen 1 de 2 Asus V500CA-DB51T Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T Hard Drive Replacement: paso 5, imagen 1 de 3 Asus V500CA-DB51T Hard Drive Replacement: paso 5, imagen 2 de 3 Asus V500CA-DB51T Hard Drive Replacement: paso 5, imagen 3 de 3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 3 Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 3 Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: paso 6, imagen 3 de 3
    • Remove the following screws securing the battery connector board to the logic board:
    • The red screws are size 2.3 cm T6 Torx
    • The orange screws are size 2.4 cm T6 Torx
  7. Asus V500CA-DB51T Hard Drive Replacement: paso 7, imagen 1 de 2 Asus V500CA-DB51T Hard Drive Replacement: paso 7, imagen 2 de 2
    • Remove the SSD (Solid State Drive) assembly from the upper case.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 565
