Saltar al contenido principal
Asus UL80VT Motherboard Replacement
Qué necesitas
  1. Asus UL80VT Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: paso 2, imagen 1 de 2 Asus UL80VT Motherboard Replacement: paso 2, imagen 2 de 2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: paso 3, imagen 1 de 1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: paso 4, imagen 1 de 3 Asus UL80VT Motherboard Replacement, Hard Drive: paso 4, imagen 2 de 3 Asus UL80VT Motherboard Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: paso 5, imagen 1 de 2 Asus UL80VT Motherboard Replacement: paso 5, imagen 2 de 2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: paso 6, imagen 1 de 1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: paso 7, imagen 1 de 3 Asus UL80VT Motherboard Replacement: paso 7, imagen 2 de 3 Asus UL80VT Motherboard Replacement: paso 7, imagen 3 de 3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: paso 8, imagen 1 de 2 Asus UL80VT Motherboard Replacement, Keyboard: paso 8, imagen 2 de 2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: paso 9, imagen 1 de 1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: paso 11, imagen 1 de 1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: paso 12, imagen 1 de 2 Asus UL80VT Motherboard Replacement: paso 12, imagen 2 de 2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: paso 13, imagen 1 de 1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: paso 15, imagen 1 de 1
    • Lift the motherboard out of the laptop and remove it from the device.
Conclusión
2 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 420
